Cam Sensor Location on 2.0L Turbo
Old Jul 27, 2006 | 12:26 PM
clyde's Avatar
Default Cam Sensor Location on 2.0L Turbo
Removed a blown-up 97 2.0L turbo engine with the cam sensor on the rear of the camshaft and installed a 99 2.0L turbo engine with the cam sensor on the front on the camshaft. Spliced the 99 cam sensor connected into the 97 wiring harness. Had to swap the spark plug wires on the coil to get the engine running because 2 & 3 were firing when 1 & 4 were suppose to fire. What needs to be done to get the plug firing back to the proper order when going from the rear cam sensor to a front cam sensor?
Clyde.
Old Jul 27, 2006 | 12:28 PM
Default RE: Cam Sensor Location on 2.0L Turbo
Cant you just switch the plug wired around?
Old Jul 27, 2006 | 12:40 PM
clyde's Avatar
The wires to the cam sensor on the 97 GST wiring harness were the same color as the 99 cam sensor connector. Originally connected the like wires together and had to swap the spark plug wires to get the firing right. When I swapped the red and black wires leaving the striped blue wires connected, the engine ran but not very good. It appeared to run as if in a degraded condition when the cam sensor is lost. I do not have wiring diagrams for either of these engines.
Clyde
Old Jul 28, 2006 | 01:10 AM
patsevo8's Avatar
have you figured it out?
Old Jul 28, 2006 | 01:12 AM
So you swapped the plug wires arround to get the right firing order... but still a problem? I would say check that the plugs and wires are good... i cant really think of another reason...
7-UP BILL
Jan 6, 2015 10:10 AM
janine
Apr 2, 2006 01:33 AM
Sallback
Nov 28, 2005 01:55 AM
Black98
Apr 16, 2005 07:23 PM
myspyder
Jun 8, 2004 09:14 PM
