camber kit??????
Old Jun 9, 2006 | 11:53 PM
DixonsGst's Avatar
Default camber kit??????
Ok im lowering the car with Tein S tech springs 1.3 inches. Also, i just purchased some KYB AGX struts all the way around. I was just wondering do i NEED a camber kit if its being lower 1.3? Is that much of a drop still gonna effect my tire wear? I know ill probably need a kit for the back but will i need one for the front? Thanks
Old Jun 9, 2006 | 11:55 PM
DixonsGst's Avatar
Default RE: camber kit??????
oh my bad i forgot to mention i have a 97 gst.
Old Jun 10, 2006 | 04:28 AM
DixonsGst's Avatar
hmmmm no body knows????
Old Jun 10, 2006 | 10:44 PM
ictponder's Avatar
I didn't know Tein made springs for the AGX struts. I was under the impression that the S-Tech springs were for OEM only.
Old Jun 12, 2006 | 11:57 AM
I dont see why it would matter, the springs should work for any struts. But as far as the camber kit, you shouldnt need it. 1.3" isnt really big enough to create a problem
Old Jun 12, 2006 | 04:34 PM
ictponder's Avatar
Aren't the front AGX struts similar to the rear...as in without the spring plate? I thought they were al the same springs, unless you go with OEM which have a wider/shorter spring for the front.
mysterio2099
Sep 8, 2006 11:36 AM
bluballz07
Apr 1, 2006 08:28 PM
bluballz07
DixonsGst
Dec 11, 2005 04:42 AM
darkman0127
Oct 4, 2004 09:12 AM
