Can I Power shift or hard shif?
Old Jun 22, 2007 | 12:31 PM
nyc95gst's Avatar
Default Can I Power shift or hard shif?
My car won't get into gear. I did some research and I think I know what I have to do. Thing is it's parked out in a public spot and I would like to move it.
Should I FORCE my car into gear? Is that possible? Is it good for my clutch/tranny?
I just want to drive it someplace better so I can work on it or even bring it to a shop.
Thanks
Old Jun 22, 2007 | 12:46 PM
Default RE: Can I Power shift or hard shif?
Can you put it in gear with the engine off? If so, then do that
Old Jun 22, 2007 | 12:54 PM
nyc95gst's Avatar
Hey Sebba, last I remember the answer is No. :[
I tried hoping it would catch. To be honest tho, I did not try that hard. You know, I didn't want to force it. I know when I push the car I can drop it into 1st, but almost can't make 2nd afterwards (tho again, I didn't want to force it).
Thoughts?
Thanks again man.
Old Jun 22, 2007 | 01:00 PM
Your tranny is done or your clutch is. Calla tow truck
Old Jun 22, 2007 | 01:07 PM
nyc95gst's Avatar
Damn, you serious? Fffffffaaaaaacccccccccckkkkkkkkkkkkkkkkkkkk!!!!!!! !!!!!!!!!!!!!!!!
Hold up. When I checked the master cylinder resv. there was no fluid inside. I was under the impression I had a leak or a bad slave. But I see what you are saying, with the car off if I am unable to put it in gear then it's more than fluid.
Aw man, I'm rushing over and making that f#$k#$ get in gear while off.
Old Jun 22, 2007 | 01:12 PM
waaait. Fill the reservoir up.. and pump the clutch pedal until all the bubbles are out.. it should work then
Old Jun 22, 2007 | 01:25 PM
nyc95gst's Avatar
Yea, I did that - nothing. Maybe I didn't pump enough? How much pumping should I do? I was by myself so I couldn't really tell if bubbles were coming out or if they stoppped coming out.
Old Jun 22, 2007 | 01:35 PM
Is the pedal stuck to the floor or anything?
Old Jun 22, 2007 | 01:41 PM
nyc95gst's Avatar
Yea it gets stuck to the floor. I was lifting it up manually to try and pump it and got nothing.
nyc95gst's Avatar
