car idling at 20 rpms?? sputtering during throttle
Old Apr 23, 2007 | 12:19 AM
matt02708's Avatar
Default car idling at 20 rpms?? sputtering during throttle
I have a 1995 eclipse GS-T and recently my car will randomly start running weird. It will idle down at what looks like 0-20 rpm's but it won't stall and when you go to take off or give it WOT it will sputter and take forever to gain mph. If I slam the throttle and hold it the rpm's will sputter and then just fly up and then the cars fine for 3-4 hours and then it will do it again. Is my butterfly getting stuck closed? Its throwing the MAF sensor code but it will only throw if I don't slam the gas and clear the problem. So i'm guessing that its only throwing the MAF sensor code because the MAF sensor is getting starved of air. Its quite odd I boosted 14 psi all day today driving around without a problem then on the way home it acted up. I slammed the gas and its been fine since. Any ideas guys?
Old Apr 24, 2007 | 07:34 PM
matt02708's Avatar
Default RE: car idling at 20 rpms?? sputtering during throttle
no suggestions?
Old Apr 24, 2007 | 07:56 PM
i would try cleaning the throttle body with some carb cleaner and see if it fixes it.
Old Apr 24, 2007 | 08:10 PM
Might be the TB or the MAF?
Old Apr 24, 2007 | 10:39 PM
BlackMurcielago's Avatar
Mine does the same but i cant remember what the guy at the shop said. its something in the throttle body like eci i dont know but i would like to see how this turns up because i need to know too.
Old Apr 25, 2007 | 01:11 AM
matt02708's Avatar
Its rare that it happens but its definitely something that didn't just go away or fix itself. I'm just gonna buy a 1g throttle body and port my intake mani, turbo, o2 housing, and exhaust mani at the same time. Problem solved. Thanks guys.
cmac1990
Apr 7, 2010 11:50 PM
cmac1990
1st Generation
Apr 4, 2010 04:41 AM
thecrew2999
Feb 3, 2009 03:34 PM
ron40
Apr 1, 2008 09:04 PM
shamsulaswad
Oct 31, 2004 07:44 PM
