car won’t start when hot
Old Nov 24, 2003 | 03:17 PM
napst's Avatar
Default car won’t start when hot
my car starts everytime frm a cold start....runs 4 bout 15 minutes n then cuts off......and won't start again unless its rested for like another 30 minutes or so....... i did a fuel pressure check and everything seems within specs.....i even checked the resistance on the fuel pump relay and ASD relay....got like 73 ohms on it....</P>
and when this happens....theres no spark either......but i just changed the coil and the wires..........</P>
im kinda torn between....if its a faulty fuel pressure regulator, the relays cuttin off when it gets hot...or leakin fuel injectors........(donno if it could b the pump)</P>
anyone experienced similar probs?....or have any idea what it mite be?...</P>
tnk u</P>
Old Dec 3, 2003 | 04:56 AM
oldmansgs's Avatar
<IMG src=smileys/smiley1.gif border="0">TRY LOOKING AT IGNITION MODULE,ALSO KNOWN AS TRANSISTOR PACK.FAILURE OF ELECTRICAL COMPONENTS CAN EASILY HAPPEN WHEN THEY BECOME HEAT SOAKED FROM ENGINE COMPARTMENT HEAT.IT'S VERY COMMON FOR COMPONENTS TO HAVE AN OPEN CURCUIT WHEN THEY ARE HEATED UP AND THEN TO REESTABLISH CONTACT WHEN THEY COOL.I'D ALMOST BE WILLING TO BET THAT THIS WILL CURE YOUR PROBLEM,HOPE THIS HELPS.</P>
Old Aug 25, 2004 | 01:24 AM
rg350's Avatar
Default RE: car won’t start when hot
Hey oldmansgs... I posted a pm for help. I have the same damned problem. Only it's gotten to point where it won't start at all again
in other words MY CAR IS ****ED
Silvertooth
May 22, 2006 05:06 PM
54321
Apr 7, 2004 11:06 PM
dazednconfuzed
Jan 29, 2004 07:47 PM
2fast4u
Sep 6, 2003 06:44 PM
