car wont start up
Old Jun 23, 2008 | 12:22 PM
clips69's Avatar
Default car wont start up
sparks on all four...spitten fuel on all four...turns over and timing is correct...yet it wont crank up...i have a 2.4l spyder with a gsx ecu and a 95 gst cam sensor(the one on the timing belt side)...any ideas why it wont start up?
Old Jun 23, 2008 | 03:16 PM
Default RE: car wont start up
MAS?
Old Jun 23, 2008 | 07:00 PM
dsm1990gsx's Avatar
J/w why do u have a gsx ecu and gst cam sensor? Do u have compression?
Old Jun 24, 2008 | 08:40 AM
clips69's Avatar
MAS??dont know what that is srry...
i have the gsx ecu to run the 2g throttle body...and the 95 cam sensor came with the head that i bought...and i do have compression...
Old Jun 24, 2008 | 12:27 PM
dsm1990gsx's Avatar
Mas is mass air sensor aka maf mass air flow. Do u have an injector pulse when you crank it?
Old Jun 24, 2008 | 03:12 PM
silvercoupe97's Avatar
Let's start with the beginning and finish with the end, ok.
How long has this been acting up? Did this just start? Did this issue work its way to the no start condition? Why do you have a turbo ECU on a non-turbo car? The TB has nothing to do with turbo fuel, timing, crank position, and other various sensor maps on a N/A motor.
Anyway, fill us in, it would help us in helping you.
Old Jun 24, 2008 | 03:18 PM
Since I don't know if your car has run in this state with the turbo ECU, I'm going to say that the no start issue is because the sensors timing signal is off timing with the ECU's timing/crank map. For example, the crank signal fires at TDC, but TDC for N/A (naturally aspirated/non-turbo car) is off a degree, two, or more. Therefor, the injectors fire NOW, but the plugs fire after saturation, or vice versa. Again, I'm shooting in the dark, so fill us in please.
The TB (throttle body) has nothing to do with the ECU other than the throttle plates position in reference to how much fuel to dump in. Again, N/A and turbo ECU maps are different.
Old Jun 24, 2008 | 03:33 PM
HOLY crap I didn't catch that!
Old Jun 24, 2008 | 03:37 PM
ORIGINAL: Sebba
I gotcha covered bro
Old Jun 24, 2008 | 03:43 PM
Dude wtf is with the code again.... now apostrophies have a problem.
