car wont start up
Old Jun 24, 2008 | 07:21 PM
clips69's Avatar
Default RE: car wont start up
srry bout that should put more info in the begining(was sorta in a rush)...but anyways it was first non-turbo until i turboed it with a gst head.(reason being why i switched out the ecu)the car was running until the cam sensor went out(that caused only 2n3 cly to spark)..then from there i put in a new 95 cam sensor on the timing belt side(the original was on the tranny side)...yet it wont crank up with all 4cly spark
Do u have an injector pulse when you crank it? yes
Old Jun 24, 2008 | 08:55 PM
dsm1990gsx's Avatar
So u have fuel, spark and compression somethings not right...should be running?
Old Jun 25, 2008 | 09:47 AM
clips69's Avatar
yea i know it should staart right up...this **** is mind boggling...doin test after test...still nothing
Old Jun 26, 2008 | 07:31 PM
jerusry's Avatar
i know it sounds dumb... but did you put the spark plugs in the wrong order? kinda hard to find it possible but.. eh.. worth a shot
Old Jun 26, 2008 | 07:56 PM
clips69's Avatar
yea deffently i made sure the wires were in the right order...the coil pack even shows the cyl #'s on the bracket to show you which coil goes to what...thanks though
GryphonsClaw
Jun 21, 2006 11:33 PM
edaddik
Jan 2, 2006 04:28 PM
tno1
Jul 8, 2005 02:36 PM
ldeemt
Jun 13, 2005 12:06 PM
red92eclipse
Oct 22, 2004 12:38 PM
