Carbon Build up
Hey guys whats the best/easiest way to clean the carbon outta the combustion chambers? Ive heard of letting them soak in mopar combustion chamber cleaner but was wondering if anyone had found another way of cleaning them. The reason i ask is i was cleaning my plugs today cause my mpg was suffering a little and decided to look inside while i could. three of the piston tops were flat black and the fourth or #1 piston was about half black and half of it i could see the top of the piston shining back at me. was just wondering what you guys thought. 98Gs-t w/108xxx miles
There are treatments that can clean some of it. bu I don't think you'll EVER get them ALL clean. I'd worry more about the carbon buildup around valves and seats then on the pistons.
Plain ol commercial decarb service kits can be used to introduce a chemical treatment into the intake while the engine is running to blow the carbon build up right out of the enhaust. It's best to do it when the engine is absolutely warmed up/hot. It is effective on most vehicles unless the carbon build up is super thick. I do this all the time at work especially with vehicles that fail smog due to high NOx emissions.
Good Luck!
Joel, CA
Good Luck!
Joel, CA
Yeah I used to use the Valvoline 3 part service kit. 1 part went into the gas the 2nd was a cleanser spray that decarboned the intake/butterfly valve, and the 3rd part was a chemical that went into the intake via the power brake vacuum line that cleans the valves and cylinders and gets all the crap blown out the back end. The final chemical takes a good 45 minutes running to go through and when you drive the car afterwards it's like crop dusting the area LOL... It leaves a HUGE cloud of smoke behind until the chemical is fully blown out of the system.
It will be something that will likely have to be done by a shop. It's a professional grade cleaner. You can get weaker cleaners that you use either on the intake or in the tank at the auto store but the 3rd part that gets sucked in by vacuum lines won't be available.
Most shops charge one hours labor ON TOP of the actual part (roughly around $50 for parts). You should be able to purchase the part alone and do the labor yourself. You'll just need something to regulate the amount of the solvent that is ingested into the intake. Good Luck!
Joel, CA
Joel, CA
