Clutch acting funny when it's cold
Old Dec 3, 2006 | 05:34 PM
djfrog2001's Avatar
Default Clutch acting funny when it's cold
Now that North Carolina has finally decided to start getting cold my clutch is acting funny. Last time we had a cold snap the clutch would sink to the floor and it very difficult to change gears. I'd had trouble with this before and changed out the clutch slave cylinder, problem solved or so I thought. Now that it has gotten cold again it has started giving me the same problem. Can anyone give me any suggestions as to what else it might be?
Old Dec 3, 2006 | 05:36 PM
djfrog2001's Avatar
Default RE: Clutch acting funny when it's cold
It's a 420a engine by the way, I'm not sure what the code is for the transmission (97 Eclipse RS)
Old Dec 3, 2006 | 07:32 PM
racerx55's Avatar
sounds like the clutch master cylinder is takin a crap,maybe the slave cyl
Old Dec 3, 2006 | 10:00 PM
silvercoupe97's Avatar
Does it do this when the motor is warmed up too? What type of fluids do you use in the clutch system and the tranny?
Old Dec 4, 2006 | 12:11 AM
djfrog2001's Avatar
Today when I attempted to drive it the clutch response stayed the same even after the engine warmed up. Right now there is DOT 3 brake fluid in the clutch reservoir. Someone mentioned the clutch master cylinder, does anyone know how much of a b***h this will be to change out?
Old Dec 4, 2006 | 12:34 AM
estraw's Avatar
its not a pain at all to change. you just gotta try your hardest not to get any bubbles in the lines, if you do then you gotta bleed it out. which is not that hard but requires 2 people to do
EDIDT: actually i would reccommend bleeding it out afterwards anyway. better safe then sorry
Old Dec 4, 2006 | 12:42 AM
djfrog2001's Avatar
I just assume that I'm going to have to bleed it. At the risk of asking for too much do you know about how much the master cylinder will cost? I paid about $55 for the slave cylinder
Old Dec 4, 2006 | 12:47 AM
estraw's Avatar
i bought a new one last year. i dont remember exactly how much but i believe around 80-100 depending on the manufacturer
Old Dec 4, 2006 | 02:33 AM
Yeah, anytime you open the lines, you're going to have to bleed it. There's just no way around that.
Old Dec 4, 2006 | 10:11 AM
Just an FYI, your engine code is 420a
