Clutch fluid leaking
Old Feb 27, 2006 | 10:41 PM
sarahs99's Avatar
Default Clutch fluid leaking
Ok my clutch fluid keeps continuing to leak and my boyfriend and i have checked from the master cylinder all the way to the slave cylinder and it is clean all the way to there but it drinks the fluid and is all over underneath my car. It is not going inside the car but has coated the whole underside of my car and is getting everywhere. has anyone ever had this problem and if so what could it be???? any advice would help greatly. thanks
Old Feb 27, 2006 | 10:47 PM
TheAdvocate's Avatar
Default RE: Clutch fluid leaking
Completely dry it all off...
How long before its covered again, and try to pinpoint the area its coming from after you dry it off..
Old Feb 28, 2006 | 12:23 AM
slow420a's Avatar
My guess its comming from either where the slave cyl meets the tranny or where the soft line meets the hard line by the fuse box... depending on what model it is, I am going to guess a 99 420a(rs/gs). Which if it is, and its the slave banjo bolt leeking remove the restrictor in the slave cyl, it does wonders.
Old Feb 28, 2006 | 09:31 AM
sarahs99's Avatar
Where is the slave banjo bolt at and where is the restictor at?
Old Feb 28, 2006 | 10:37 AM
get435's Avatar
check where it is mounted to the firewall id say about 70% of the time this area will get little cracks in it from pedal abuse and will overtime weeken and crack.
Old Feb 28, 2006 | 06:45 PM
slow420a's Avatar
http://www.2g nt.com/nuke/modules.php?name=Sections&op=viewarticle&artid=75
(remove the space between the "2g" and the "nt" for the link to work correctly, if you post them togather they say 2gnt.com)
Old Feb 28, 2006 | 11:55 PM
sarahs99's Avatar
Ok we found out that the master cylinder is leaking inside the car but a majority of the fluid is underneath the car. Can this be possible and has it happend to anybody else?
Old Mar 1, 2006 | 03:34 AM
Sanguinius's Avatar
How would the master cylinder be leaking INSIDE the car? I've never heard of that... The only place fluid IS for the clutch system is in the master cylinder (Mounted on the firewall), in the slave cylinder (Mounted on the trans), and in the line between the 2. Therefore the leak from the master cylinder likely runs down the line and drips off either a low point or off the slave cylinder. If you have something leaking INSIDE the car that would be either antifreeze (Which means a bad heater core) or water (Which means the condensation drip line is clogged) if you have liquid inside check what it is (Antifreeze tastes somewhat sweet and the water will taste like... well... water...)
Old Mar 1, 2006 | 10:31 AM
slow420a's Avatar
It could be leeking from the mater cyl and running down the arm into the cab.
Old Mar 1, 2006 | 11:01 AM
ORIGINAL: Sanguinius
Just what i want to be drinking....antifreeze, LOL
newoutlanderfan
May 27, 2013 10:47 AM
cptkid570
Nov 15, 2007 07:09 PM
Natedogg89
May 8, 2007 12:38 AM
davidmitsusrock
Aug 4, 2006 01:05 AM
jcasaccio
Jun 6, 2006 06:14 PM
