clutch and flywheel
Old Oct 6, 2006 | 04:00 AM
  #21
jerusry's Avatar
Default RE: clutch and flywheel
actually i did know about that, never thought to eliminate that switch tho... i actually know a lil more then you'd think.. =) but thanks for all the help, me doin my own clutch was def a good learning experience. i like to have **** go wrong sometimes.. so i know how to fix it later orwuteve.. but anyways, i will let you know how all that stuff goes.thanks again!
Old Oct 12, 2006 | 11:55 PM
  #22
franco's Avatar
Is resurfacing the same as having the flywheel turned?????
Old Oct 13, 2006 | 12:16 AM
  #23
ORIGINAL: franco
yup
Old Oct 14, 2006 | 12:35 PM
  #24
OldSchool's Avatar
If the clutch did have a pilot bearing/bushing you should change it. What can happen if you do not is with a fair amount of wear, the bushing will wear big and the input shaft will have play in it, if it is a bearing, the needle bearings can eventually come out and be a problem. Bushings are usualy bronze for this type of application if it has one. Also, there is a bearing/bushing removal tool that would make it easy. Did anyone verify if there is such a part for this application?
sk8dudety
Nov 12, 2007 10:37 AM
97spydergs
Oct 29, 2007 02:14 PM
EVO_CANEVO
Sep 28, 2007 06:29 PM
gstgurly22
May 12, 2006 09:16 PM
95HGeclipse
Mar 29, 2006 08:16 PM
