Clutch issue...
Old Sep 2, 2008 | 09:02 PM
TheAdvocate's Avatar
Default Clutch issue...
Ive never dealt with this until now.. But while driving for long distances on the interstate/hwy, when I go to push in the clutch I lose pressure and it acts as if its not disengaging.. This will also happen if I let the car sit for a week.. Ill have to pump the clutch to build up pressure or bleed the clutch line.. Im not losing fluid anywhere, the master isnt leaking, nor is the slave. However, the clutch fluid looks really dirty, even after just bleeding it and refilling the resevoir. Any deal with this before, or any thoughts? I have a few but I would like some others before I just start trying stuff.
Old Sep 2, 2008 | 09:10 PM
dsm1990gsx's Avatar
Default RE: Clutch issue...
I have went through that once before and it was air in the system. Try using a vacuum pump.
Old Sep 2, 2008 | 09:31 PM
Ive done that.. It works for about a week, but then it just starts doing it again.. Somewhere something is letting air in the line slowly, but Im not sure what is doing it..
Old Sep 2, 2008 | 09:48 PM
It may not be leaking, but it is letting air in some place. I am betting its the master
Old Sep 2, 2008 | 10:02 PM
They do that? I know they've been known to leak but you can see it on the inside of the car... Ive never heard of it just letting air in.
Old Sep 3, 2008 | 07:27 AM
Its for sure a hydraulic issue, the question is WHERE.
focusedblur
Apr 22, 2011 04:22 PM
theend
Nov 10, 2010 07:57 AM
chutney374
Oct 2, 2010 11:48 AM
nyc95gst
Jan 11, 2007 01:09 AM
koodalgo
Mar 28, 2006 12:07 AM
