Code P0125 Help
Ok so I had the check engine light turn on and I got it scanned and reset, it came on again it was P0125 - Inadequate collant temp for closed fuel circuit.(In other words the car is taking too long to reach operationg temp) I looked on obd-codes.com and it said that it is eaither a stuck thermostat or a bad coolant temp sensor. The gauge reads that the car is warmed up and the heater is definently hot so do you think that it is the sensor or the thermostat?
codeaholic
Feb 25, 2011 09:52 PM
