Code P0125 Help
Old Jan 7, 2008 | 05:40 PM
dorian7's Avatar
Default Code P0125 Help
Ok so I had the check engine light turn on and I got it scanned and reset, it came on again it was P0125 - Inadequate collant temp for closed fuel circuit.(In other words the car is taking too long to reach operationg temp) I looked on obd-codes.com and it said that it is eaither a stuck thermostat or a bad coolant temp sensor. The gauge reads that the car is warmed up and the heater is definently hot so do you think that it is the sensor or the thermostat?
Old Jan 7, 2008 | 05:46 PM
Default RE: Code P0125 Help
Sensor is my bet...
Old Jan 7, 2008 | 05:48 PM
id start with the temp sensor
Old Jan 7, 2008 | 06:08 PM
dsm1990gsx's Avatar
Isn't there a spec for ohming the sensor? You might as well replace the sensor, replace the thermostat and flush the coolant. How old is the coolant in the car?
Old Jan 7, 2008 | 07:06 PM
dorian7's Avatar
the sensor only costs $22 so I am going to start with that. The coolant is about a year old.
dangan
Feb 12, 2015 03:13 AM
menacemonty
Nov 12, 2012 10:45 AM
codeaholic
Feb 25, 2011 09:52 PM
hussain74
Aug 24, 2006 09:34 PM
Gregory
Mar 11, 2006 01:28 PM
