cold air intake
Old Aug 29, 2005 | 06:09 PM
bigwilly8941's Avatar
Default cold air intake
sup everybody um i need to get sum opinions on the best cold air intake for my 97 gs-t.
Old Aug 29, 2005 | 10:17 PM
vinceaton's Avatar
Default RE: cold air intake
I'd go with an AEM
Old Aug 30, 2005 | 10:01 AM
get435's Avatar
injen
Old Sep 1, 2005 | 10:10 PM
DSMTalonAWD51's Avatar
no cold air intakes for a 97gst unless you drill a huge hole through metal. buy a k&n filter and adapter for $80 and thats all you need. You can also build a custom sheet metal cold air box around the filter like I did to keep the temps lower.
Old Sep 4, 2005 | 10:16 AM
get435's Avatar
ORIGINAL: DSMTalonAWD51
for what?
Old Sep 5, 2005 | 11:06 AM
what do you mean for what? for a 97gst. no turbo cars can have cold air intakes unless you drill a huge hole.
Old Sep 5, 2005 | 11:19 AM
get435's Avatar
it just a question becuse i am curious but where are u talking about driling a hole.
Old Sep 5, 2005 | 01:53 PM
slow420a's Avatar
ORIGINAL: get435
cold air intakes sucks "cold" air from under the car, where a short ram intake sucks hot air from under the hood. On the gs't, gsx's, and tsi's there is no room for the filter to go "south" to suck cold air thus to make a CIA you have to cut a 3-4" hole in the frame of the car.
As you can see in the pic the filter is jammed in a rock and a hard place with no way to suck cold air.
Old Sep 5, 2005 | 02:20 PM
get435's Avatar
ok i understand what coldir intake was but was just wondering wht he was drilling you learn somthing new every day.
Old Sep 5, 2005 | 11:41 PM
you can drill a hole under the filter and send a custom pipe down there if you want. i didnt dot hat because if i ever plan to go back to stock i will have a huge hole where the stock airbox goes. instead you can also make a custom sheet metal enclosure around the filter and it keeps the hot under the hood air a lot cooler arouund the filter.
apw5060
Sep 23, 2011 08:00 PM
kaiba408
Feb 14, 2007 06:56 PM
kniel023
Dec 28, 2006 12:51 AM
600$eclipse
Apr 20, 2003 05:15 PM
