Compression Test results
I would think so... heres a better way to find out whats going wrong. Drizzle a LITTLE oil down cyl #1 and do the test again. If the numbers are much higher.. then your problem is piston ring seal. If not, then its the gasket : )
How would my car have a bad head gasket it never over heated. Tho when i got engine form junk yard it had a bad themostat which when driving would over heat a tiny bit and then go back to normal. I changed the thermostata day later.Would that be the cuase of my bad head gasket.
