Compression Test results
Old Aug 24, 2007 | 08:59 PM
grim0reaper0's Avatar
Default Compression Test results
My mechanic did a compression test on my 97 eclipse rs and the results were 160,180,180,180. Wt u guys think bad head gasket?
Old Aug 24, 2007 | 09:03 PM
Default RE: Compression Test results
I would think so... heres a better way to find out whats going wrong. Drizzle a LITTLE oil down cyl #1 and do the test again. If the numbers are much higher.. then your problem is piston ring seal. If not, then its the gasket : )
Old Aug 26, 2007 | 01:57 AM
How would my car have a bad head gasket it never over heated. Tho when i got engine form junk yard it had a bad themostat which when driving would over heat a tiny bit and then go back to normal. I changed the thermostata day later.Would that be the cuase of my bad head gasket.
Old Aug 26, 2007 | 03:45 AM
racerx55's Avatar
nothing lasts forever
those motors just puke head gaskets at random.
you could also have burnt valves causing a slightly lower compression,... 20 psi isnt THAT bad.
is that cold? hot? dry? wet?
Old Aug 26, 2007 | 04:37 AM
mxmikie's Avatar
yea i hate random puking
Old Aug 26, 2007 | 06:42 AM
dry
Old Aug 26, 2007 | 07:06 PM
i agree with sebba. Put alittle oil in there, repeat and see. Hopefully the # doesnt change. Then its only the head gasket.
Old Aug 26, 2007 | 07:40 PM
I dont think it would be a valve not seating correctly... because it would have been a lot less...
Old Aug 26, 2007 | 08:21 PM
nick_200321's Avatar
more than likely it is the gasket that is blown through over by the #1 Cylinder.. woudlnt it be real easy just to pull the head off and see??
Old Aug 26, 2007 | 10:01 PM
Before doing anything like that.. you dont think its easier to put a little oil down the cylinder?
