Cranking but not starting issue
Old Nov 12, 2012 | 11:11 PM
WxDarklingxW's Avatar
Default Cranking but not starting issue
Hey Guys could use some real help on this, I have a 1996 Eclipse RS and it is cranking but not starting. I've replaced the Starter, ignition coil, ECM, spark plugs, spark plug wires, Fuel pump and ASD relays. Now a curious thing happened I replaced my Ignition switch fuse and my car started once and didn't again. I checked the fuse and isn't blown. And with the key in the on position I get a 12v reading on the fuse terminal. So could it be something is shorting after the fuse gets hit? Please Help I need my car for work.
Old Nov 14, 2012 | 08:26 AM
mxmikie's Avatar
got fuel ???? timing belt marks line up ??? got spark ???
Old Nov 14, 2012 | 08:47 AM
Default solution
Yeah I was getting fuel but no spark, I traced my wiring and found out that the pigtail connectors for the ecm was messed up. I was getting signal out from my ecm but not to ignition coil. I bought the pigtail connectors at a junk yard wired em up and it started without a problem.
Old Nov 16, 2012 | 07:57 AM
mxmikie's Avatar
how did the pigtail connectors for the ecm get messed up ????
Jmwatson14
Jan 13, 2016 06:14 PM
TheMitz
Mar 6, 2015 04:27 AM
Scubba.steve
Oct 11, 2008 01:11 PM
jamesdthomas2
Jul 1, 2007 02:06 PM
irdefector
Jul 6, 2006 07:23 PM
