Custom gauges are here! Need help on install!
Old Aug 9, 2007 | 08:29 PM
dorian7's Avatar
Default Custom gauges are here! Need help on install!
So here are the custom gauges! The only problem is that I cant get the needles off! Do you just pull, because I was pulling pretty darn hard and they wouldnt come off! any help would be appreciated!
Old Aug 9, 2007 | 08:58 PM
jlh077464's Avatar
Default RE: Custom gauges are here! Need help on install!
hmmm those are growing on me...its a unique touch.
Old Aug 9, 2007 | 08:59 PM
jlh077464's Avatar
Oh and I think you just pull., i took mine off and painted the back...i dont recall doing anything special.
Old Aug 9, 2007 | 09:09 PM
Kaede.Noir's Avatar
theyre really nice haha, if they were mine, i would get the GSX letters black =)
Old Aug 9, 2007 | 09:13 PM
chopper1's Avatar
on page 2. https://mitsubishiforum.com/m_161760/tm.htm
Old Aug 9, 2007 | 09:14 PM
silvercoupe97's Avatar
Use a fork to pull or pry them up. Seriously.
Old Aug 10, 2007 | 07:17 AM
RCJr9186's Avatar
I used needle nose.
Old Aug 10, 2007 | 12:12 PM
I Drive Naked's Avatar
Use a small flathead screwdriver.
I did a write up on gauges
https://mitsubishiforum.com/m_156755/tm.htm
That will help you alot with calibration b/c when all done, your needles WILL be off.
Old Aug 10, 2007 | 12:49 PM
RCJr9186's Avatar
I wasn't sure if the needles were off once i installed my new gauges or if it was b/c i went form 16" - 18" rims... ora combo of the 2. I thought it was fine b/c before installing the gauges i held them up infront of the stock ones and the numbers seemed to be IDENTICAL.
Old Aug 11, 2007 | 03:11 AM
dorian7's Avatar
Thanks for the help guys, hopefully I will get around to it soon!
