Custom gauges are here! Need help on install!
So here are the custom gauges! The only problem is that I cant get the needles off! Do you just pull, because I was pulling pretty darn hard and they wouldnt come off! any help would be appreciated!
on page 2. https://mitsubishiforum.com/m_161760/tm.htm
Use a small flathead screwdriver.
I did a write up on gauges
https://mitsubishiforum.com/m_156755/tm.htm
That will help you alot with calibration b/c when all done, your needles WILL be off.
I wasn't sure if the needles were off once i installed my new gauges or if it was b/c i went form 16" - 18" rims... ora combo of the 2. I thought it was fine b/c before installing the gauges i held them up infront of the stock ones and the numbers seemed to be IDENTICAL.
