daily driver acting up
Old Feb 13, 2005 | 08:11 PM
baker_sk8er37's Avatar
Default daily driver acting up
lets see i have had so many problems with it the past couple of weeks it has broke down like 5 times adn its teh same thing
the batter is showing eitehr low volts or none
i have changed the (fuel pump) battery the alternator and the starter because that went and its still doing the same dam things showing no volts
i thinkn it might be a wiring issue
help please i am out of ideas
Old Feb 13, 2005 | 09:41 PM
GST WNB's Avatar
Default RE: daily driver acting up
Check some of the power/ground wires,in the engine,it might not be getting the full connetshen of the wires,if it's not showing alot of volts on the meter,that probaly means maybe a bad connet or something,or bad ground wire
Old Feb 13, 2005 | 11:22 PM
customizedrides's Avatar
I would also do an amp draw test. You may have something drawing off the battery when it shouldn't be. Does the ar start up right away?
ByPopularDemand
May 30, 2008 06:51 AM
MrJayDeeOne
Jul 3, 2007 06:23 PM
antox18
Nov 11, 2006 11:14 PM
Maximus99
May 28, 2006 01:22 AM
davids2004
Jun 20, 2004 11:09 PM
