damn check engine light
Old Feb 14, 2008 | 12:37 AM
ffateale's Avatar
Default damn check engine light
O.k. no major mods on my 97 eclipse GST. Check engine light does'nt wanna shut off. I've gone to autozone, CODE P0505-Idle control Valve - replaced twice now, once when i first purchased it and just recently. Still the damn thing keeps lighting up, i've pulled the negative as well, but that reset it for a couple of days, then the light comes back on again. I'm getting tired of disconnecting the battery every other day, anybody got any suggestions?
I hav'nt tried running the code again but i'm sure it'll pull up as P0505 again. Any help???
Old Feb 14, 2008 | 12:40 AM
98gstspy's Avatar
Default RE: damn check engine light
go buy a code reader and leave it in the car every time it comes on erase it jk i dont know what that means but i was what i used to do when i needed a new oxegen sensor
Old Feb 14, 2008 | 06:35 AM
Do you experience any idle issues? It could be a few things. Try cleaning out your Throttle body and also check the throttle cable that everything looks correct there. The next thing would be the Throttle position sensor. Oh yea and also check the harness and wires to the IAC
Old Feb 14, 2008 | 11:03 AM
ffateale's Avatar
i dont have any idle issues now, but about a2 month ago i did and replace the cam shaft & crank shaft positioning sensor. BUT i do remember back in repair shop receipt back in 2004 mechanic took it in because of the check engine light andengine was idling rough - mechanics found air temperature reading abnormal/ found excessive resistance at IAT circuit at ECU connector due to faulty connection. He charged me 368 bucks to reposition connector and change out some bad spark plugs and wires.
could this be the same issue? I'll check IAT and IAC connections.
guyjg
Nov 13, 2021 03:27 PM
pgb205
Jun 4, 2009 10:40 PM
antlip
Mar 2, 2008 01:10 PM
c577
Oct 16, 2007 12:03 AM
CH69NO
Aug 28, 2007 10:59 AM
