damn rattling windows
Old Oct 6, 2007 | 06:20 PM
nyc95gst's Avatar
Default damn rattling windows
Ok, my windows are rattling, but when I took off my door paneling and tightened the bolts nothing improved. The noise/rattling is still around. It looks like there are some bolts I can't get too that are loose. Does this mean I have to take out the whole metal inside of the door? Is this easy to do?
Thanks
Old Oct 6, 2007 | 06:57 PM
itsme71190's Avatar
Default RE: damn rattling windows
i got the same problem. i cant figure it out ither. i think it may b the tracking for the window
Old Oct 6, 2007 | 08:11 PM
tjbiker031's Avatar
is it rattling on the top of the window or bottom?
Old Oct 6, 2007 | 11:22 PM
sk8dudety's Avatar
there is a write-up on here somewhere about it... but what you have to do is pull the window out of your door. on the front of the window (side closest to fender) you'll see the piece that is attached to your window that run along the window track. it'll have a little white piece inside of it where "clamps" onto the window. This should come off with i believe a 10mm socket, all you have to do is take a pair of plier, squeeze that part together (not to much cause then your window wont be as easy to open). Put it back on, slip your window back in, problem solved
Old Oct 6, 2007 | 11:40 PM
tjbiker031's Avatar
yea i saw it but mine rattle on the top of the window, when the windows are down, i have no idea how to fix it.
Old Oct 8, 2007 | 02:31 PM
nyc95gst's Avatar
well the problem is this little plastic piece that fits onto the front track. It fell off and I am trying to put it back on. If I can get it on then squeeze the metal together I think my rattling will end.
Old Oct 8, 2007 | 05:12 PM
TSG59_Steve's Avatar
ORIGINAL: sk8dudety
The write up is on tuners, which is a *** word on here. Otherwise I'd provide the link.
Old Oct 8, 2007 | 07:45 PM
nyc95gst's Avatar
Thx, so I'll look it up.
Old Oct 9, 2007 | 01:16 PM
sk8dudety's Avatar
d s m tuners.com?
Old Oct 9, 2007 | 03:27 PM
Natedogg89's Avatar
Here this is the writeup for a 2G http://www.dsmtalk.com/forums/showth...threadid=90915
ukrkoz
Jul 8, 2008 07:22 PM
01SpyderGT
Nov 20, 2005 06:23 PM
Tmann26
Apr 16, 2005 04:47 AM
Tmann26
Apr 11, 2005 05:35 AM
Rode
Mar 10, 2004 04:58 PM
