Rattling in front wheel
Old Nov 20, 2005 | 05:52 AM
01SpyderGT's Avatar
Default Rattling in front wheel
When I'm making a left hand turn there is a grinding feel in the steering wheel and a rattle coming from the front passanger side wheel. It only happens when I'm turning or in the morning when I'm excelerating to get on the freeway. I took it to the dealer and they "fixed" the problem. However, two days later it started doing it again. I took it back and they told me they had fixed the problem and that the only thing they could do is look at the car again and give me an estimate. I was reading some recalls for my car and it mentioned a nut loose in the gear box. I don't know if this could be it or not, but any information would be appreciated. I have a 2001 Spyder, 5 spd manual.
Old Nov 20, 2005 | 09:44 AM
Default RE: Rattling in front wheel
sounds like a wheel bering or maybe a ball joint. your Gear box is on the drivers side so I doubt it is that.
Old Nov 20, 2005 | 06:23 PM
FireDoc's Avatar
I agree. When you turn there is obvious stress on the bearings and, the car being front wheel drive, a hard acceleration is applying the same type of stress. I am not sure about your mechanical inclinations, but checking/greasing/replacing bearings is generally not a huge undertaking. I don't have ANY knowledge about your generation of eclipse. If you drive it like a race car, maintain it as such. If you love the corners as I do, you really have to pay attention anything that will have to work hard. Bearings, bushings, etc.
sk8dudety
May 31, 2014 08:55 AM
se4448
Oct 29, 2007 03:00 PM
eclipse6racer
Dec 23, 2006 06:16 PM
trbodsm997
Dec 25, 2004 01:52 AM
Rode
Mar 10, 2004 04:58 PM
