Dash lights
Old Jan 21, 2008 | 06:06 PM
tuckGST's Avatar
Default Dash lights
I have an issue with my instrument lights. Everything that runs off the dimmer switch is out. No speedo, tach, AC dials nada. Looking at the dimmer plug there are 3 wires - a black/yellow wire, brown (I think), and Black.
If I connect the power lead (black/yellow) to the ground will it bypass the switch? I don't need the dim function right now just lights.
Old Jan 21, 2008 | 07:34 PM
dsm1990gsx's Avatar
Default RE: Dash lights
If you have no dash lights check your fuses.
Old Jan 21, 2008 | 08:37 PM
TheAdvocate's Avatar
ya.. If you dont have ANY lights.. Most likely a fuse..
Old Jan 21, 2008 | 08:49 PM
tuckGST's Avatar
I have all the warning lights, srs, check engine, brake, brights, both turn sigs....everything that is controlled by the dimmer switch is out. All fuses are good (that was the first thing I checked. I also replaced all bulbs.
Monte98
Dec 8, 2010 01:46 AM
claytonkobe
Sep 19, 2010 12:28 PM
Scott01Sport
Nov 14, 2005 11:18 PM
Ricsta
Feb 12, 2005 10:11 AM
Ripley
Dec 19, 2004 04:39 PM
