Did i go over my head vs V8?
Old Feb 10, 2006 | 12:47 AM
  #51
TheAdvocate's Avatar
Default RE: Did i go over my head vs V8?
He already has big enough injectors in the car for a 20g... I would be looking at a bigger turbo tho, if you truely want to win... You said you have a bigger fuel pump already? You could go with a bigger turbo safely for well under 5,000... You wouldnt have to worry about that.. You could actually go with a lot bigger turbo.. But with a bigger turbo you would have to make sure your injectors could keep up with it/your fuel pump, the hard piping to help air flow, and a nice front mount intercooler to cool that beast of a turbo down... Also you will prolly need a different exhaust manifold, because most of the bigger turbo's mount differently and won't work on the stock exhaust manifold.. You could lose all the extra weight to gain a little bit, but on an average its only about .10 of a second for every 100 lbs of fat you cut down on your car..
Heres a link to a chart that you could choose a turbo that would fit your needs...
http://machv.com/tursumchar.html
Old Feb 10, 2006 | 12:58 AM
  #52
anko_kun's Avatar
ok every one calm down
Old Feb 10, 2006 | 02:06 AM
  #53
Silvertooth's Avatar
What are they cooling down from?
Old Feb 10, 2006 | 02:15 PM
  #54
Sanguinius's Avatar
I know enough about cars to be dangerous to myself and others... Also yes approximately 100 lbs = .10 but that ALSO depends on the HP of the car. If he's upping HP and reducing weight... Or upping HP by adding bigger beefier parts then removing the extra weight the ways I was talking then his curb weight will stay similar or even be a little lower while making big HP jumps. Besides it's free to rip shyt outta your car yourself. Yeah for 5K I'd say big turbo, FMIC, injectors and fuel pump, FPR (Fuel pressure regulator), boost controller, exhaust manifold, and if you don't have it already 3" exhaust piping. Then take the rest and get some dyno time to get her tuned right.
Old Feb 10, 2006 | 03:22 PM
  #55
Yeah I always forget about saying getting it tuned right...upgraded parts don't work well unless you get them running in sync....
Old Feb 10, 2006 | 03:41 PM
  #56
Sanguinius's Avatar
Dude how much do YOU know about cars? Or do you read what we say and regurgitate? I mean seriously...
Old Feb 10, 2006 | 04:57 PM
  #57
Meh I know the basics. I don't try to give advice I don't know. Was just saying I always forget to mention tuning whenever someone asks SPECIFICALLY for my opinion, like, my friend Matthias. Tell him some things that he can do to his 300ZX, but always forget to mention tuning.
Old Feb 10, 2006 | 06:25 PM
  #58
dreamz's Avatar
With Turbo and bigger injectors and pump with headers and intercooler in wouldnt i need to to upgraded my ECU or get piggy back also i couldnt find headers for gs-t i could only find it for gs or rs at tunning shops am starting to painc with parts also can i do anything else to my ignition sytem other plugs and wires ?
Old Feb 10, 2006 | 06:26 PM
  #59
anko_kun's Avatar
sang is correct the tuning is the most important thing u could dump 10 grand in to it and not get any were with out someone who knows how to tune the car like u want it to so be carful
Old Feb 10, 2006 | 06:30 PM
  #60
NESpeed's Avatar
ORIGINAL: dreamz
Yes get a SACF, you should already have one since you said you where running bigger injectors.
