Do I need a heat shield
Old Mar 4, 2008 | 06:07 AM
tuckGST's Avatar
Default Do I need a heat shield
I have a 97 Gst with only the intake modded. basically stock everything else. I've noticed a small spot off water/coolant on the ground when I park it overnight. the spot is about 3 inches or so in diameter. I've traced the leak to the upper coolant line to the turbo.
I've tried to remove the heat shield to get to it, but I've sheered the head right off the bolt. the leak is small. I put about a 20 oz bottle of water in it every 2 weeks.
my question is...do I need the heat shield, or can I get by without it? This car has to stay my DD for about the next year before I can rip stuff off for upgrades.
Old Mar 4, 2008 | 06:19 AM
Default RE: Do I need a heat shield
the heat sheild is only there for 1. to protect yourself from touching it 2. to try and keep the engine bay temps down alittle bit by forcing the hot air away from it. But it really isnt necessary
Old Mar 4, 2008 | 08:47 AM
sk8dudety's Avatar
yea man you'll do fine without it, no worries
Old Mar 4, 2008 | 09:19 AM
atown420's Avatar
i want a tubular manifold. especially that custom one SICKNESS. they look so amazing especially with a polished turbo.
Old Mar 4, 2008 | 09:22 AM
bestwiseguy's Avatar
^^^^^ Ok that was random lol.
Old Mar 4, 2008 | 09:58 AM
Rob's Avatar
Rob
Port and jet coat ftw!
Old Mar 4, 2008 | 10:46 AM
sk8dudety's Avatar
how much does it cost to jetcoat a stock manifold? i was thinking of getting it done, 1)for the better heat capture, and 2) so it looks way better than not jetcoated
Old Mar 4, 2008 | 11:29 AM
Rob's Avatar
Rob
Call Buschur's to get the best price.
https://secure.buschurracing.com/cat...28057a54266957
Old Mar 4, 2008 | 12:16 PM
sk8dudety's Avatar
yea i just looked that up right after i asked the question thanks
Old Mar 4, 2008 | 04:13 PM
RCJr9186's Avatar
TheEngineer is right on, on that one. You dont' need it thought. If you have stripped a bolt, just do the rest and pull the shield off then grab the bolt w/ some pliars or something and try to screw it out after soaking the bolt in some wd40 or so. you can get an aftermarket manifold pretty cheap (200-300) (that's VERY cheap in the car world) if it bothers you that much.
newoutlanderfan
Apr 8, 2014 09:55 AM
tuckGST
Feb 17, 2008 06:18 PM
osushinobu
Jul 30, 2007 03:45 PM
dksnj
May 10, 2006 10:50 AM
EclipseGS
Oct 12, 2004 02:39 PM
