Eclipse GS dead
I got a 1996 eclipse gs from this lady for $700, i'm thinking of swaping a 4g63 in but for now I would like to fix the regular engine 420a, she was telling me that when she was driving all of a sudden smoke started coming out of the hood. When I took the car from her I tried starting it up and it seems the smoke is coming from the intake manifold, what is wrong with the car and how can I fix it? I need to fix this engine because i'm low on cash and can't purchase the new one. Any info will help Thanks
RE: Eclipse GS dead
Take off the intake manafold and see if the head gasket or the valve cover gaskets are leaking at all. if that is not the problem check the line that goes from the intake manafold to the valave cover where the pcv valve is to make sure it is not leaking. if you dont want to take the anafold off just jack the car up and look from underneath the car although your view may have some obstruction you can see most of everthing. also check some of the things like where the oil filter goesinto the block and the crank pos sensor anything that can have a broken seal that is leaking oil on the motor. Did the lady say anthing about overheating or anything?
RE: Eclipse GS dead
She did say that the car once overheated because she didn't have any water in it. Can this be another factor for oil in the engine.
RE: Eclipse GS dead
Again like I said a bad head gasket, let me guess the smoke is white. Thats coolent smoke, blue smoke is oil smoke. Plus that would explain why the coolent level went down. If she did run it with out any coolent... tha could be bad. OOOOOk the block is cast iron, the head is alunmium. When the motor overheats(bad) the metal gets super hot. Since the head is alunmium it warps. So what may of happen their was a head gasket leek and the coolent went on a bus to dickhead town and the motor over heated and the head got hot, REAL hot. When it cooled down it may of warped, which would explain the extreme amount of smoke.
RE: Eclipse GS dead
Will this make the engine start, cuz when I try to start it, it sounds like if the battery was really low. i've checked several batteries on teh car and it still sound like that. And its when i'm trying to turn on the car that the white smoke comes out of the intake manifold. Would the head being warped or leak be a factor for the engine not starting. Any info much appreciated Thanks
RE: Eclipse GS dead
First check that the battries are still good that your trying. Also what color is the smoke, blue/ white/ PINK? When you say that the smoke is comming from the intake manifold I am assuming that its comming form under it. What may be happening, the head gasket is letting water into the cyl's and putting out the spark. So it may be impossible to start and I dont reccomend driving it/ starting it. If a cyl. isant firing all of the other cyl's have to take the load of moving that cyl up and down. This is called d1111ragging a piston. It can cause the other bearings to fail.
RE: Eclipse GS dead
Yes the batteries are good, i'm positive. The smoke is white and its coming from the intake manifold, because I took off the intake and I saw when the smoke was coming out of it.
RE: Eclipse GS dead
ORIGINAL: vertigo14k Yes the batteries are good, i'm positive. The smoke is white and its coming from the intake manifold, because I took off the intake and I saw when the smoke was coming out of it. |
RE: Eclipse GS dead
ORIGINAL: get435 ORIGINAL: vertigo14k Yes the batteries are good, i'm positive. The smoke is white and its coming from the intake manifold, because I took off the intake and I saw when the smoke was coming out of it. I dident think that it was litteraly comming out of the intake manifold. Well then its deff a head gasket problem. Your getting water into the cyl's, which wont let the motor start. ITs like trying to start a fire in a rain storm, extremely difficult. |
RE: Eclipse GS dead
ok i think where it is coming from is not clear i though he said it was coming from the intake manafold when he took it off the car so there would be no way it is a head gasket i may have took what he said wr9ong but if u have the intake off the head and smoke is coming out of the intak manafold the only thing that would cause the problem is a bad pcv. if the smoke is coming from the area on the block where the intake anafold mounts and not from the intake mamafold than it may be a head gastket or a valave cover gasket.
