RE: Eclipse GS dead
this is what i'm going to do i'm going to replace the pcv valve with a new one and then we'll take it from there. I will go and buy a new pcv valve and then I will post what has happened since I put on the new pcv valve. Thanks again everyone
RE: Eclipse GS dead
I beg to differ. If the white smoke is coming from the intake manifold then it's likely at lesat the intake manifold gasket and possibly a head gasket. The PCV valve wouldn't cause that though it should probably be replaced anyways due to the fact that who knows when it was replaced last and it SHOULD be replaced every 30K. The PCV valve being clogged will blow out the valve cover gasket LONG before any other ones.
RE: Eclipse GS dead
ORIGINAL: get435 .... there would be no way it is a head gasket i may have took what he said wr9ong but if u have the intake off the head and smoke is coming out of the intak manafold the only thing that would cause the problem is a bad pcv... |
RE: Eclipse GS dead
I was just on 2 g n t.com and ran across this... enjoy.
http://forums.2gnt.com/dcboard.php?a...8904&mode=full EDIT: for some reason the if you type 2 g n t togather it comes up as 2gnt. so heres the gist of it. Post starter My pcv valve just broke and I needed to drive the car out. So I simply replaced it with a 3/8" silicone heater hose because I thought any hose should work. But once installed, my car began shooting out a great amount of white smoke (it does before but not that much) and also a funny burning smell. What was happening? I'm just gonna get a new pcv valve, no big deal, but just wondering what caused that to happen, thanks reply owned headgasket It goes into more detail, but i guess you can kinda draw conclusions from the bit I gave you. |
RE: Eclipse GS dead
I have replaced the pcv valve, and I tried turning on the car but it won't turn on, when i'm trying to turn it on, it makes poping sounds like it something is not doing its job. I took of the intake again and I smelled gas. like if it wasn't burning.
(This is out of nowhere I was talking to some guy and he said that it may have been the timing belt. I don't remember exactly what he said, but that it has to get timed again, and something about that he valves got messed up) |
RE: Eclipse GS dead
ORIGINAL: vertigo14k I have replaced the pcv valve, and I tried turning on the car but it won't turn on, when i'm trying to turn it on, it makes poping sounds like it something is not doing its job. I took of the intake again and I smelled gas. like if it wasn't burning. (This is out of nowhere I was talking to some guy and he said that it may have been the timing belt. I don't remember exactly what he said, but that it has to get timed again, and something about that he valves got messed up) |
RE: Eclipse GS dead
OK i'm sorry if i'm asking stupid questions but i'm new to all this stuff, Where can i get a cyl pressure gauge and how do I do the compression check. Where do I stick what and what do I have to take off. Sorry again but thanks for taking ur time in helping me.
RE: Eclipse GS dead
You can get a cylinder compression gauge at any auto parts store or sears or whatnot. As for how to test you'll take out a spark plug and screw the gauge line in then you'll have someone crank the engine over while you watch the gauge.
RE: Eclipse GS dead
ORIGINAL: slow420a ORIGINAL: get435 .... there would be no way it is a head gasket i may have took what he said wr9ong but if u have the intake off the head and smoke is coming out of the intak manafold the only thing that would cause the problem is a bad pcv... |
RE: Eclipse GS dead
check the spark plugs to see if there is any dsposits from coolent or oil on them here is a site for some ex. http://www.gnttype.org/techarea/engine/plugs.html
