Eclipse GST potential?
Old Oct 24, 2005 | 12:35 PM
  #21
wicked_outlander's Avatar
Default RE: Eclipse GST potential?
theres no such thing : TURBO C.A.I. if, you want a cold air , get a bigger intercooler.
Old Oct 24, 2005 | 01:06 PM
  #22
slow420a's Avatar
ORIGINAL: Lil red
IF the tb sucks air from the crank case by the pcv valve would the air really be that muck colder even with a cai on a normal car?
if your worried about the pcv valve what do you think about the egr valve... lol. Like sang said its minimal. The motor its self is hot once the air enters the motor it gets hot.
Old Oct 24, 2005 | 03:33 PM
  #23
Sanguinius's Avatar
Exactly not only that but the POINT of a CAI is to reduce the temp of the air going in to reduce overall temp. Think about it this way: I have a pot of boiling water and a pot of ice water. I put them on similar heat for 1 minute which one would YOU stick your hand in afterwards? Every degree cooler the air going in even though it DOES get heated it's STILL a degree cooler than it would have been if warmer air went it.
Old Oct 24, 2005 | 06:48 PM
  #24
Lil red's Avatar
OOOHHHHhhhhh Just wanted a yes or no awnser... Sorry to get your panties in a bunch sang....
Old Oct 25, 2005 | 11:40 AM
  #25
Sanguinius's Avatar
What good is a yes or no answer if you don't understand the WHY??? If you know WHY then you'll remember the answer later in life and you'll understand the workings of things a bit better. And the more you understand about the engine workings the better you'll be at making it work how it's s'posed to and squeezing out that last bit of HP from it.
Old Oct 25, 2005 | 07:00 PM
  #26
Lil red's Avatar
So if my valve is clogged it is enough pressure to make my car run rough? I had a bad pcv valve on a sunbird and the car ran like **** at certain speeds and had crappy gas milage. stupid three dollar part.
Old Oct 25, 2005 | 08:12 PM
  #27
Sanguinius's Avatar
It shouldn't cause it to run rough. It'll just blow out the valve cover gasket
Old Oct 25, 2005 | 09:22 PM
  #28
Lil red's Avatar
It would run rough at about 70 mph but if i drove 60 it was fine. changed the pcv valve and it ran fine never had that problem again. It was ohc and i used a rubber gasket with metal inserts around the screw holes.
Old Oct 26, 2005 | 12:16 AM
  #29
hasenbonkers's Avatar
ok so like i said before. say u get a new BOV, intake, and Boostcontroller. How much faster would it make it. It runs mid 15s stock, so wut would u estimate the time would be with little mods like tht.
speedy_tC
May 25, 2008 04:22 AM
epia225
Feb 1, 2008 11:34 AM
jmvcar
Nov 12, 2007 02:52 PM
BrunoBoy650
1st Generation
May 24, 2006 09:31 PM
Yargk
Jun 21, 2004 06:52 AM
