Eclipse GSX won't idle
Old Aug 7, 2005 | 09:26 PM
eclipsen's Avatar
Default Eclipse GSX won't idle
My 96 eclipse GSX recently decided it doesn't want to idle. It does start from cold (choke keeping idle). After it warms up, it won't start unless I give it gas. And while driving, as soon as the clutch goes in, the engine RPMs drop right to 0 and it shuts off. Does anyone have any ideas? Could it be a sensor? I haven't changed anything for over 3 years. It runs fine except it won't idle. Mods have been K&N filter, Greddy BOV, boost at 15psi, hard IC piping, full turbo-back exhaust. All this was done over 3 years ago with no problems since. Thanks, Aaron
Old Aug 8, 2005 | 02:27 AM
DSMTalonAWD51's Avatar
Default RE: Eclipse GSX won't idle
if your venting your bov try adjusting the bov or is you want better performance dont vent at all. if thats not it check all vacuum lines
Old Aug 8, 2005 | 02:49 PM
eclipsen's Avatar
My BOV is recirculating. I already did a quick check on the vacuum lines and IC piping. All looked OK.
Old Aug 8, 2005 | 04:40 PM
wicked_outlander's Avatar
hmmmm....no leaks at all??[:-] try to re-set your computer...
Old Aug 8, 2005 | 10:34 PM
check your BISS, o2 sensor, and make sure your maf is plugged in all the way
Old Aug 8, 2005 | 11:45 PM
g9s5t's Avatar
idle speed control possibly bad.. not too uncommon
Old Aug 9, 2005 | 09:27 PM
cocosun's Avatar
Having this same problem with my 2003 GS. Found out today the idle sensor needs to be replaced. Check your coolant levels too as I was told my engine got too hot and that fried my sensor.
Old Aug 16, 2005 | 02:33 PM
eclipsen's Avatar
I checked both the TPS and IAC and they measured fine. Cleaned the throttle body and stuck it all back together. It worked for about 5 miles then it won't idle. Checked the IAC again and one of the windings was open. I'll update this thread after I put in a new (or used) IAC. Thanks guys!!
Old Aug 18, 2005 | 06:28 PM
TheAdvocate's Avatar
I had this problem shorlty after I got mine. Someone told me the fuel control valve.. Then I was told it could be a sensor.. And in the end, my motor was on its way out... A week later I had to replace the whole motor, b/c a piston hit a spark plug and I lost compression in all the cylinders...
Not a cinderella story
Old Aug 28, 2005 | 11:43 PM
eclipsen's Avatar
Finally got an IAC off ebay. Everything is working fine now. Thanks for all the help.
dennison
Jan 20, 2011 09:06 AM
schiffma
Feb 28, 2009 07:45 PM
sassee
Sep 13, 2008 08:54 PM
Mobiledj
May 29, 2008 10:34 AM
djbjez
Mar 31, 2008 07:50 AM
