Eclipse - locking the door with key in ignition
Old Dec 8, 2005 | 08:52 PM
jlhowie's Avatar
Default Eclipse - locking the door with key in ignition
Hi All,
I have a question. In the north country we sometimes find it handy to start our cars, lock the door and return to a nice warm car. When it's -10 to -20 below zero it's almost impossible to sit in a cold car while it's warming up. Is there a way I can lock my door with my engine running?
Thanks in advance!
Old Dec 8, 2005 | 09:07 PM
Sanguinius's Avatar
Default RE: Eclipse - locking the door with key in ignition
Sure you can lock the door witht he engine running. My Nissan does it automatically now (Well the alarm system does it actually) it's actually considered a safety feature. Just make sure you have a key to the door on the outside when you lock it LOL...
Old Dec 8, 2005 | 09:52 PM
jlhowie's Avatar
The doors do not lock. I think this is a safety feature so you don't have the problem you described, of locking your keys in the car. Is there an override or a trick that will work?
Thanks!
Old Dec 8, 2005 | 10:56 PM
Joel_CA's Avatar
It is a safety feature to prevent you from locking your keys in the car- a simple way around it is to lock the door when the door is closed (engine still running). Of course this will mean that you have to use 2 sets of keys in order warm up your vehicle with this method.
Joel, CA
Old Dec 9, 2005 | 12:27 AM
eclipsed4u's Avatar
its not possible in my eclipse. if the keys are in the ignition and i have the door open and try to lock the doors, they won't lock. they will lock, then unlock again.
Old Dec 9, 2005 | 04:10 AM
Sanguinius's Avatar
I'd say either get a remote start installed or use a 2nd key to lock the door from the outside once the car's running.
Old Dec 9, 2005 | 04:37 AM
Joel_CA's Avatar
As i said.. close the doors 1st then lock it with your 2nd key. It's the same thing as if you lock the door from the inside with the engine running. So long as the doors are closed...
Joel, CA
Old Dec 9, 2005 | 11:03 AM
get435's Avatar
this is simple here is what i do the dor continues to un-lock itself when it is open now take your finger and push the slideer to t he locked pos and close the door.
Old Dec 9, 2005 | 05:19 PM
diki9111's Avatar
Or get out through the trunk.
Old Dec 9, 2005 | 07:22 PM
TheAdvocate's Avatar
Just dont lock the car with the remote lock...
