Eclipse Start's but can't rev, :(
Old Jan 18, 2014 | 03:44 PM
mbspyder's Avatar
Default Eclipse Start's but can't rev, :(
Hi, my 99 Eclipse GS Spyder, isn't running well, I used some engine degreaser, and i had to clean it up lightly with some water with the engine off, after cleaning and drying, the eclipse can start, but if I try to rev, even a little bit, the engine hesitates a lot and if I rev more, it just dies,
I tried opening the throttle body and air filter to let any stuck water evaporate, I pulled the spark wires off to let any water evaporate, I also sprayed a little wd40 into the plug connectors to drive out any water, also tried pulling tps sensor connector to see if it would run better, nothing has worked.
It is the 2.4L 16 valve motor sohc
Will have a video up soon,
I know i'm a noob for getting water on the engine, but what can I do about it,
Old Jan 18, 2014 | 04:29 PM
mbspyder's Avatar
Default Video of problem
<iframe width="420" height="315" src="//www.youtube.com/embed/VB02kUNu964" frameborder="0" allowfullscreen></iframe>
Old Jan 18, 2014 | 04:30 PM
mbspyder's Avatar
erg, that didn't work, its here:
Old Jan 18, 2014 | 08:36 PM
Akzle's Avatar
so it holds a good idle?
Old Jan 20, 2014 | 02:57 AM
mbspyder's Avatar
it hesitates at idle a little bit, but the idle is not high, the hesitation gets intense if i try to rev
Old Jan 20, 2014 | 03:45 AM
Akzle's Avatar
timing not advancing, my first suspicion.
vacuum leaks or sensor issue.
Old Jan 22, 2014 | 06:37 PM
mbspyder's Avatar
Default sensor
I suspect a sensor, i will get it checked with a scanner soon, had no timing issues before the gunk
Maro
Aug 4, 2015 09:29 AM
lillysdaddy21
Jul 14, 2012 09:04 AM
voodo1
Apr 11, 2012 08:19 PM
ashulee12
Oct 21, 2008 04:22 AM
xp8ntballkid309x
Jul 12, 2007 08:30 PM
