eclipse will not crank HELP!
I have a 1995 eclipse 2.0 dohc non turbo , i bought it and had been sitting about a year i finally got it cranked only for a few minutes and then it shut off and now will not even try to crank, i put new plugs new coil new fuel pump it is firing and gas is going all the way to fuel rail but will not even act like it wants to crank, is crank sensor bad or cam sensor or ecm, all 4 plugs are firing and the timming is lined up perfect on cams, i am lost on this one.
uh, this happed to my friends 95 tsi and he said there is an oil pressure switch somewhere and he said it was bad and when he put a new one in, it started right up. just from what im hearing, because his did the same thing, even sprayed started fluidd and kicked over for a second and died, so maybe the same problem.
oops129
Jan 4, 2006 04:38 AM
