eclipse will not crank HELP!
Old Jul 6, 2006 | 07:25 PM
gthutch's Avatar
Default eclipse will not crank HELP!
I have a 1995 eclipse 2.0 dohc non turbo , i bought it and had been sitting about a year i finally got it cranked only for a few minutes and then it shut off and now will not even try to crank, i put new plugs new coil new fuel pump it is firing and gas is going all the way to fuel rail but will not even act like it wants to crank, is crank sensor bad or cam sensor or ecm, all 4 plugs are firing and the timming is lined up perfect on cams, i am lost on this one.
Old Jul 6, 2006 | 08:15 PM
93eclipsegsx's Avatar
Default RE: eclipse will not crank HELP!
so you turn the key and nothing??
Old Jul 6, 2006 | 08:20 PM
gthutch's Avatar
oh no it will turn over and over but will not even act like it wants to fire but all plugs are firing even sprayed starting fluid in intake and nothing
Old Jul 6, 2006 | 08:33 PM
uh, this happed to my friends 95 tsi and he said there is an oil pressure switch somewhere and he said it was bad and when he put a new one in, it started right up. just from what im hearing, because his did the same thing, even sprayed started fluidd and kicked over for a second and died, so maybe the same problem.
Old Jul 6, 2006 | 08:39 PM
gthutch's Avatar
well i will sure give it a try nothing else seems to work, thanks
Old Jul 10, 2006 | 03:33 PM
gthutch's Avatar
No luck with the oil pressure switch, this one has really puzzled me but when it is all over i am sure it will be something simple , anyone has any ideas please let me know,
Thanks
Old Jul 10, 2006 | 07:26 PM
could it be your spark plug wires not connected to the coil pack right???
Old Jul 12, 2006 | 05:29 PM
gthutch's Avatar
I checked wires they are all connected right , I think i will get me a new crank senor and cam sensor and try that , i will let you know how that turns out, thanks for all the help.
Old Jul 12, 2006 | 07:20 PM
hope that does it. your welcome
Jonv420a
Nov 28, 2012 03:19 PM
Jonv420a
Nov 28, 2012 02:43 PM
maidenquest
Aug 1, 2006 07:01 PM
oops129
Jan 4, 2006 04:38 AM
Next_level
Nov 17, 2005 04:04 AM
