Eibach lowering
Old May 4, 2006 | 02:19 AM
B.e.R.a.T's Avatar
Default Eibach lowering
hey guys
Who owned buy car before me cut the front springs and it started to **** me driving it like that because it is too freakin low and my car jumps when I hit the bumps. I don't have enough money right now to put coilovers on my car so I decided to go with Eibach pro kit. I read all the old articles about it but I wanted to ask you guys one last time. If I replace my springs with eibach pro kit without changing shocks and struts also without putting a camber kit how is my driving going to be. instead of putting eibach should i just go buy factory spring and just replace the front springs. please give me some opinions[sm=smiley5.gif]
Old May 4, 2006 | 03:18 AM
DSMTalonAWD51's Avatar
Default RE: Eibach lowering
eibachs are good springs, for sure the ride wil be better than cut springs, but without a good shock paired they will be a stiffer bouncy. stock shocks arent stiff enough for the springs and will wear the stock shocks out faster.
Old May 4, 2006 | 10:22 AM
RCJr9186's Avatar
eibach is very expensive, you can buy a set of Skunk2 coilovers for like 290 and i hear they are an awesome brand.
Old May 4, 2006 | 11:39 AM
eclipsed4u's Avatar
ORIGINAL: RCJr9186
you can get Eibachs for cheaper than that..... http://www.nopionline.com/nopistore/...Eclipse%201998
Old May 4, 2006 | 12:56 PM
RCJr9186's Avatar
true you can get springs seperate for a cheaper rate but you can get a set of coilovers for 279 at slowboyracing
Old May 4, 2006 | 03:02 PM
ncyankeealva's Avatar
Well if you don't have money, and you are going to lower your car your tires are gonna wear out especially with aggressive driving....
Old May 4, 2006 | 03:37 PM
eibach pro kit/ tokico illumina shocks = best affordable combo for 2g dsms, id avoid coilovers
Old May 4, 2006 | 03:59 PM
RCJr9186's Avatar
i was under the impression that coilovers were better to have than shocks and struts
Old May 4, 2006 | 07:04 PM
eclipsed4u's Avatar
ORIGINAL: RCJr9186
you are thinking of true coilovers. Skunk2 (i believe) are the spring type coilovers. NO TRUE COILOVER is going to cost under $600. True coilovers are the best( JIC, TEIN SS).
Old May 4, 2006 | 08:09 PM
5Tizzle's Avatar
yeah those cheap "coilovers" are just little adjustable cups that you put under your springs, so you can adjust your ride height. theyre pretty low quality and worthless
guygsx
Mar 9, 2008 09:57 AM
redpgt
Apr 7, 2006 05:43 PM
ziggy88
Mar 14, 2006 01:51 AM
Wingmansd
1st Generation
Mar 13, 2006 05:59 AM
badmonkey
Mar 10, 2006 01:19 PM
