Engine Fans
Old 01-27-2007, 05:45 PM
50ul }{4ck3r's Avatar
Default RE: Engine Fans
i just changed all the coolant like three weeks ago
Old 01-27-2007, 07:23 PM
Sanguinius's Avatar
First off check the coolant level. Top off if necessary. Then open the hod and let the car run. As it comes up to normal temp watch to see if the fans kick on. Now If they do then there may be another problem I.E. clogged coolant passages, weak water pump, clogged radiator. Running both fans may keep it a little cooler BUT it's a temporary fix.
Now if you still want to run both the fans together I'll have to look at the wiring schematics and see how to do it. I can run my Conquest's fans at the same time by running a single jumper from one thermoswitch in my radiator to the other thermoswitch. But I'm not sure how the 4G63 or 420A engines determine temps for fan actuation.
Old 01-28-2007, 12:52 AM
ORIGINAL: 50ul }{4ck3r
You dont think you could get a leak? Check it.
scitron
11-23-2007 06:03 PM
noel380
1st Generation
11-08-2006 10:53 PM
scitron
08-20-2005 08:38 PM
TheNeck
07-14-2005 02:40 PM
silvia240cnvrsn
12-22-2003 02:16 PM
Quick Reply: Engine Fans
