both cooling fans are not working, is it the norm?
Old Sep 2, 2005 | 06:25 PM
scitron's Avatar
Default both cooling fans are not working, is it the norm?
When my AC is on, the fan on the right is not functioning, only the one on the left. Is this the norm ? Does the other fan turn on when it reaches a certain temp? If its broken, is it easy to replace? Thanks for your help.
Old Sep 2, 2005 | 09:34 PM
TheAdvocate's Avatar
Default RE: both cooling fans are not working, is it the norm?
Mine turn on only after it gets to a certain temp... But my Eclipse GS that i had, rarely turned on... Is your car overheating a lot?
Old Sep 3, 2005 | 01:45 AM
fastcars_loudguitars's Avatar
Generally one is set for the AC, turn the Air on and see if they both kick on...after its hot, of course.
Old May 13, 2007 | 06:06 PM
scitron's Avatar
Hello,
How would I know if the compressor is shot? What would a new go four? Its a 95 galant but in very good condition and I would want to keep it.
thanks for oyur help,
Sam
Old May 13, 2007 | 09:11 PM
silvercoupe97's Avatar
If your compressor wasn't working, you wouldn't get cold air.
As for the fan, it's only a 12v fan. Check it with a 9volt battery by connecting one to the plug? If it turns the fan, chance are, your motor is not reaching temps to turn on or you a/c temp switch is bad.
Old Sep 28, 2007 | 04:38 AM
glen5122's Avatar
just test it by supplying it with 12v and a neutral.
Old Nov 23, 2007 | 06:03 PM
smokinu6's Avatar
actually if you know any vechles with elec fans when the ac on both fans should come on if the freon is low the ac will not work and the condensor fan will not come on .just the cooling fan will come on when the temp reaches 212.
Kevsie
Jan 15, 2017 05:30 PM
vinnprocassi
Jan 1, 2012 11:36 AM
totoblue
Sep 10, 2008 03:45 PM
jdmitsu
Sep 17, 2006 06:51 PM
