cooling fans....
Old Jan 1, 2012 | 12:00 AM
vinnprocassi's Avatar
Default cooling fans....
Why would one cooling fan stop working? Do both cooling fans operate through the Temp Sending Unit? Is one fan supposed to stay on after the ignition is in the Off position?
Old Jan 1, 2012 | 11:36 AM
_93TSI_370+K_'s Avatar
When the AC is on, they both should run but only one will run when the water temperature rises above a preset water temperature. As for the fan continuing to run after the ignition is off it is probably for the radiator water temperature. It is common on some vehicles for the radiator fan to run after the ignition is turned off, but I do not know specifically about your car.
Kevsie
Jan 15, 2017 05:30 PM
BlackKat52
May 24, 2012 11:02 AM
totoblue
Sep 10, 2008 03:45 PM
scitron
Nov 23, 2007 06:03 PM
jdmitsu
Sep 17, 2006 06:51 PM
