Engine Modification... HELP!
Old Feb 29, 2004 | 05:20 AM
toaster_power's Avatar
Default Engine Modification... HELP!
Hi!</P>
Im a new member...<IMG src=smileys/smiley17.gif border="0"></P>
I Have a Eclipse 94 2.0 non-turbo, and i want to put a 6cylinder 3.1 Twinturbo (the3000gt motor)Wath is the modification i can make for that?</P>
Thanks!</P>
Old Feb 29, 2004 | 05:21 PM
nate5023's Avatar
that will cost a ton of money to put a 3000 gt engine into a eclipse
Old Feb 29, 2004 | 06:15 PM
I can put myself... I have buy the engine with 20000km only 2000$</P><edited><editID>toaster_power</editID><editDate>38046.6781712963</editDate></edited>
Old Feb 29, 2004 | 10:28 PM
nate5023's Avatar
no to install it, and it might not work because, of compression, and all of that stuff
Old Feb 29, 2004 | 10:40 PM
Wath problem can i have?
Old Feb 29, 2004 | 10:42 PM
nate5023's Avatar
the compression of the car could be bad and not start
Old Feb 29, 2004 | 10:53 PM
Why can i have problem with the compression? The engine is new?
Old Mar 1, 2004 | 02:21 PM
SpyderGS's Avatar
Toaster power, i'm fairly sure that without a shop and a good welder, you can't swap in a 3000gt motor(also the displacement is 2997cc's or 3.0l). Go and put your car side by side next to a 3000gt and you'll see the 3si is much wider. The tranny is different(you are talking about the twin turbo, right?) ad therefore the axles willbe different. None of your current wiring or ecu will work, you'll have to switch to a 3si ecu and custom wiring or do stand-alone, which may be cheaper.You'll also need a custom exhaust manifold and intake manifold. So here's a break down: Cut and re-weld the chasis to widen it. Replace entire front suspension with 3si. replace ecu and wiring. custom fab manifolds and other piping(waterlines and pipes along with rad). But nate, if he get's a bad motor then yeah compression would be bad. But to install and everything, no need to worry about compression.
Old Mar 2, 2004 | 12:52 PM
The 3000gt twinturbo have 320hp and the eclipse 94 Turbo have 220hp (say me if its wrong) but i can lost the hp i win with a 3000gt motor with the weight of this 6cylinder motor?</P>
</P>
Old Mar 2, 2004 | 06:37 PM
Spyderman9803's Avatar
The 4g63 motor is a proven high performance motor and it would be ALOT cheaper to upgrade the stock motor over dropping in a 3000GT motor. The swap is not worth it at all.
