engine questions
engine questions
i don't know if this is in the right thread or not, but here goes. I have a blown head gasket... boo on that $#:T but it happens.. I recently bought a cometic head gasket, HKS timing belt (because I might as well replace that while I'm at it) and ARP head studs... now i need some opinions.... Should I just take care of all this and call it a day... or.... I'm getting some loan money in soon and could afford a new engine.... a beast of an engine.... and in that case... should I go with slowboy's destroked 2.1 monster.... or their 2.3L stroker.. I only have a PTE 50 trim on my car... so I don't need the stroker to help it spool up... I don't know... just want some opinions.. Thanks everyone
RE: engine questions
i wouldnt bother with the stroker engines. Just building up the block would be more than enough with that turbo and youd save alot of money. Id say just fix this problem then build stuff later. Always start with a good motor before upgrading . BTW you might want to replace water pump, tensioner, and seals while your in there
thanks guys... I really appreciate the input... So TheEngineer, you're just saying to replace pistons, seals, rods, etc... like a full overhaul? I can do that haha..... maybe if I have a week of free time...on another note.... is there an easier way to release the tension on the tensioner arm? The haynes manual says that you have to use mitsubishi special tool... uvaweojfnoiuaewjfiojawio.... but I don't feel like buying this and then having to find the damn hole it fits into on the back.. can't I just kinda clamp down on the arm somehow to release the tension?
The tool is the easy way of doing it and you can find them on ebay for cheap. Like the engineer said before building the 2.0 would be a much better idea then buying a stroker. Personally I would just throw the hg back on this guy and start your own motor, buy a trashed 6 bolt and do a basement build. Then in the spring drop her in.
Thanks bro... that does sound like a great idea... I just have to find the time for it. I love working on my car and noone else has touched it except me... thats half the reason it isn't painted yet... it just sucks when you can only give it 2 maybe 3 good hours a week ya know?
Lithium
11-16-2009 05:44 PM
