Engine swap?
Old Feb 10, 2006 | 12:29 AM
slow420a's Avatar
Default RE: Engine swap?
Depends on what you want done far as parts and labor, I quoted rcj9186 5g's for just parts, but that was for a motor that would support 300 hp like it was nothing. Then again you can get a compleat bottom end that would handle up to 30psi(the hg blows around here depending on the TQ on the head bolts and type of hg) for 2400(core not included). Then again it depends on what you wnat. If you only want to run 10 psi, just get the car re ringed for 400 bucks(cots of kit) and dont worry about it. IF you wnat to go bit your looking at some cash.
Old Feb 10, 2006 | 02:51 AM
eclipse27's Avatar
Well i don't know alot about boost and all. Put it this way i have an exhaust and cold air intake. I want to have atleast 250 horses. How much psi would be good to achevie this goal?
Old Feb 10, 2006 | 10:44 PM
slow420a's Avatar
err... 10 will get you to 200, so 15 ish, also depends on bolt ons, but 15 proly do you good. At the minimum you need to get a fully built bottom end, pistons rods rings bearings, stage 2 turbo kit, mbc, upgraded bov, full 3 inch exaust, injectors, safc, and a clutch.
Old Feb 11, 2006 | 01:24 AM
eclipse27's Avatar
Well i have a custom borla exhaust on it. And an air intake. A bottom end rebuild, how much will that push me? Right now i have a blown head gasket and am taking my heads to get shaved and checked. Should i tell the guy to do anythign else since im gonna be there?
Old Feb 11, 2006 | 05:44 AM
slow420a's Avatar
well their are n/a rebuilds and boost rebuilds. If your going to boost the car your going to want to lower the compression which will make the car slower n/a, and you wouldent get any gain untill you turbo the car. Where if you were making a n/a car you would raise the compression making the car faster. But the gains over raised compression n/a motor and low compression turbo motor are like the differences between a dodge caravan and a mustang gt... in a nut shell if you want to boost the motor get a bottom end rebuild, howellautomotive.com sells a whole kit for 1000, other wise dont worry about it.
Old Feb 12, 2006 | 12:38 AM
eclipse27's Avatar
I just read an article on a 420a and 2.4 litre chrysler engine swap. Good idea?
Old Feb 12, 2006 | 05:45 PM
slow420a's Avatar
Ya but you need to get a custom oil pan if you want a down pipe, a custom hood because the 2.4 sits 2 inches higher then the 2.0, and if your still looking to stay n/a dont bother doing it.
rstoevo
Jan 20, 2013 10:47 AM
kiwii29
Jul 31, 2009 01:18 AM
greg999
Dec 1, 2003 10:49 PM
mekka
Oct 17, 2003 07:51 PM
tristanlee85
Jul 2, 2003 01:29 AM
