Engine tapping
Old 11-09-2005 | 05:56 PM
Joel_CA's Avatar
Default RE: Engine tapping
Yes, it WILL do it initially but will quiet down within the 1st few seconds of engine operation under normal conditions. Aside from that, why do you need to take off the head? To replace the lifters, you'll need to remove the timing belt and camshaft only. If for some other reason you actually do need to remove the head- be sure to use the update MLS (Multi Layered Steel gasket available from the dealer (420A engine). Good Luck!!
Joel, CA
utopia2004
09-05-2011 08:34 PM
jeffgolem
12-06-2006 01:34 PM
Spyder887
08-07-2006 10:14 PM
paintballproam
07-14-2006 07:10 PM
Dans Talon
10-15-2004 12:06 PM
