eprom into a 2g
eprom into a 2g
is it hard to wire a eprom ecu into a 2g 2.4l gs spyder. i would imagine its almost the same as any 2gen gst. but im just curious because i got a eprom and will eventually get dsm link. and just in case people are wondering why im doin this its because i have all the parts to swap a dohc 1gen head and turbo ready but im gettin the ecu trouble out the way 1st
RE: eprom into a 2g
theres a whole write up on 4g64.com about it in the performance section but i dont understand it and i dont understand why its necessary. ill post it up when i get home but anyone know why it would be difficult
RE: eprom into a 2g
Victim619, that link is to get more fuel into the 4g64 in hopes of adding a turbo later.
If you're going to swap in a 6 bolt 4g63 later, then I suggest waiting until then because you will have to swap the wiring harness and ECU then. If you do this now, you will just do double the work later.
RE: eprom into a 2g
im doin it all at once by saying im getting the ecu out the way i meant the trouble of it. i want to figure it out before i have it all in. so then i guess the instructions on the write up is wat i have to do right? because i basically have the whole top end of an jdm evo 3 (4g63)
xsenergy1
12-07-2007 11:09 AM
