A fountain in the park
Old Feb 9, 2005 | 10:13 AM
Dans Talon's Avatar
Default A fountain in the park
I had oil leaking down out of the one side of the valve cover. Tightened her down a little more and it went away.
Then after a mo. it came back.
Tried torquing it down a little harder but was afraid that I would 'pop' the bolt, making it jump a thread before the rubber gasket got compressed good enough. Well, I did, [:-] the bolt 'popped', I thought it might have snapped , but it was ok, just back it off a little then start again.
Turns out I couldn't tighten the valve cover down enough to stop the leak.
So I decided to take it off and run a bead of RTV across the leaky area and then try to tighten it down as best I could. This should fix it.
I noticed that the oil pan gasket had a bead of "leak" all the way around it and also the oil dipstick keeps popping up out of its tube ??? [>:]
WTF??
Is my crankcase compression/pressure too high ? (forcing oil out of the crevices?)
Checked the vetilation/PCV found no problem . ??
Bad ring somewhere ? (Gettin' compression down past the ring into the pan??)
So while the valve cover was off I decided to start the engine and take a few seconds to watch it run to see if I see blowby gasses rising up out from the head.
Man ! (No blowby seen but..) those rocker arms (pressure relief valves with their nipples facing the lid of the valve cover) did this really neat kind of 8 stream 3' high fountian of oil []
Looked kinda neat
Gave me a big claean-up job to do though, oil everywhere, inside-a bout 4 seconds [>:]
DT
CB12xlRiCh
Oct 6, 2005 10:30 PM
jtwells
Oct 4, 2005 12:44 AM
CB12xlRiCh
Aug 4, 2005 12:40 PM
CB12xlRiCh
Jul 11, 2005 05:47 PM
EliteM6
May 15, 2005 03:04 AM
