Fresh 420a engine
Old Sep 26, 2005 | 02:05 PM
DSMTalonAWD51's Avatar
Default RE: Fresh 420a engine
your engine builder should tell you all you need to know about breaking it in.jus my opinion, but id say get oil changes at 500,1500 miles, from there you are fine. Use a thicker oil at first like 20w-50 so everything seals properly. at 1000 miles you should take it back and re-torque the head/have everything reinspected to make sure nothing came loose.
as for breaking in the motor, there are 2 ways and most people only believe one or the other. Some say to baby it, ex 1st 500 miles stay under 3k rpms etc. I believe that will lead to a weak motor. Most perforamnce enthusiasts understand that motors need to be driven a little more rough, especially during the first 100 miles so the valvetrain seats properly. I dont mean drive off and start drag racing, but try to vary the rpms a lot. In other words, stay off of freeways where the rpms are just going to stay at the same speed the who drive. stick to stop and go traffic, hills, curves, and shift frequently.
Old Sep 26, 2005 | 02:11 PM
get435's Avatar
ORIGINAL: eclipsed4u
ORIGINAL: slow420a
ORIGINAL: get435
i just rebuilt my motor and the macinest said min of 1500 miles on regular oil no less.
Thats his opnion, talk to any other mechanic and they will tell you differently.
"AFTER 500 TO A MAXIMUM OF 1000 MILES OF SERVICE, change oil and filter"
http://www.enginesonly.com/break-in.html
i think you guys are talking about two different processes. i think get435 is saying to use regular oil for the first 1500 miles, whether you change the oil or not. most of us know, on a new engine build, you should change the oil about every 500 miles. i think get435 is saying that when you do change the oil, continue to use regular oil for the first 1500 miles. i DO NOT think hes saying to not change the oil for 1500 miles
YES you nailed it.
Old Sep 26, 2005 | 02:15 PM
get435's Avatar
ORIGINAL: DSMTalonAWD51
here is the only problem i have with this. and this was told to me by the macinest use 5w-30 for the first 1500 "delaer recomened weight. the reason for so is there is a ton of builders compound in the motor and one of the resons of using regualr oil is to get all the parts clean so it seats right. like i said this was told to me by a macinest and every motor that i have had built the same thing was told to me. i wold check with the person that is building the motor just to make sure.
Old Sep 26, 2005 | 09:01 PM
slow420a's Avatar
Never listen to satan(dealer), I they never have anything good to say. Its always bring the car in, we know what we are doing. I went there for a stock rebuild and the guy behind the counter tryed to tell me just to put a 4g63 block in the car and call it a day. He said that the trannys were the same, along with the heads, ecu, and such. He didnt like it when I told him that he was stupid.
Old Sep 26, 2005 | 09:09 PM
Sanguinius's Avatar
On my new car (Granted it wasn't a fresh rebuild it was brand new off the lot) I drove it like i do now From dead starts I run it up to redline before dropping into 2nd then doing the same there then I usually skip to 4th (Cuz I'm gonna be cruising at a steady spead LOL) when I get to 5th I really don't push it too hard I usually stay around 3500 RPM. I did that till I hit around 3K miles and did the first oil change. After that I've been beatin the car at times mercilessly (Let's see 120 MPH down I-95 for about an hor in pouring rain....) LOL. And she runs like a champ!
Old Sep 27, 2005 | 12:24 AM
g9s5t's Avatar
one of your first drives should be at 30-40 mph then full throttle to 50-60 mph and then off throttle back down to 30-40 then back up to 50-60 about 10 times.. seats rings against cylinder walls properly
00GalantMan
Apr 2, 2007 11:50 AM
wicked2407
Oct 23, 2006 10:32 PM
Gsteclipse22
Feb 20, 2006 02:57 AM
specialgoodness
Feb 16, 2006 04:05 PM
690hp
Mar 22, 2005 07:48 PM
