Front Brakes on a 97 GST
RE: Front Brakes on a 97 GST
It is as easy as removing the tire . All you have to do is jack up the car, take the tire off and then take two bolts off the caliper, there are four there so make sure you take the right ones off. Its gonna be behind the caaliper (NOT the ones with the rubber boot on them. That will remove the caliper right out from the rotor, now just take out the pads, and here is the only pain part, you need a large clamp so that you can re-compress the cylinder on the caliper, it looks like a piston. Just use the old pads as a surface to clamp onto. and compress it till its flush. Put in the new pads, put it all back togetherand your good to go
You dont have to do that. You remove the pin and the caliper slides open.. you push the piston back into the caliper.. and replace the pad... clamp it back down and put the pin back in... sorted
u can push it back by hand.
EDIT: Not the caliper itself. The caliper you can slide open.. and remove the old pad.. and then push the piston back into the caliper enough so that you can get the new pad back in... You just beed to put force into it.
Yes it can be done just with your hands...
ORIGINAL: Sebba
