front main crank seal
Old Feb 4, 2007 | 02:33 PM
gst4me's Avatar
Default front main crank seal
hey guys i finally got my parts to do my front main crank seal.... how do i break the bolt loose on the crank? is it right or left hand thread? i tried to use an impact gun (1000 lb trq) but i couldnt budge it.... Any help would be awesome!.... thx
Old Feb 4, 2007 | 02:48 PM
racerx55's Avatar
Default RE: front main crank seal
Its normal right hand thread. You might need a bigger impact to break that loose. If you have a manual trans put it in 5th gear then have a helper hold the brakes & use a breaker bar,
Just a tip if you can still run the engine the bolt comes out alot easier when its warm sometimes.
Old Feb 4, 2007 | 06:24 PM
Joel_CA's Avatar
Wow- please tell me the brand name and model of an impact gun with that much power?
J
Old Feb 4, 2007 | 11:47 PM
estraw's Avatar
aircat 1/2 inch twin hammer 1000-ft-lb air impact wrench
Old Feb 5, 2007 | 12:33 AM
racerx55's Avatar
What youve never seen a good impact before? lol. 1000 Ft Lb rating is max output, if your not feeding it enough air volume it wont do near that. Like the cheap *** regulators that come on small compressors cant flow near enough CFM to run those.
IR thunder gun is a nice one to have
Did you get your bolt out?
Dave Braun
Feb 22, 2012 03:14 PM
CT67GTX
Jan 6, 2008 01:24 PM
matthew_m75
Aug 8, 2007 11:06 PM
bigchief2472000
Mar 12, 2006 04:59 PM
xxkels
Nov 23, 2004 02:30 AM
