Fuel injectors
Old Mar 15, 2006 | 01:38 AM
B.e.R.a.T's Avatar
Default Fuel injectors
Can anybody tell me what would be the best performance fuel injectors to put into 97 gst
Old Mar 15, 2006 | 10:19 AM
Default RE: Fuel injectors
it all depends on what kinda mods you plan on doing in your car. If you don't have anything do play with the fuel (SAFC...ect) and/or a turbo kit then it is kinda pointless to upgrade the injectors right no. Just give us an idea of your plans and we can help you out.
Old Mar 15, 2006 | 01:16 PM
550s are good for the 16G turbo and 20ish PSI maybe a little more. That is good enough if you dont plan on getting a a massive turbo
Old Mar 15, 2006 | 01:29 PM
B.e.R.a.T's Avatar
I am planning to put a stage 2 turbo and change the under drive pulley also run a 3" exhaust system. could u guys tell me what would be the best upgrade turbo without messing with the internals. My goal is to hit 350 hp on my car so what should I do?
Thank u 4 all the replies
Old Mar 15, 2006 | 01:37 PM
a "stage 2 turbo" says nothing. I hate when people say that really there is technically no such thing. tell us what Turbo brand size ect and we can tell you where ti go.
the big 16G can get you 350HP you might need 660 cc injectors a fuel pump and a GOOD tune
Old Mar 15, 2006 | 02:10 PM
B.e.R.a.T's Avatar
I was planning to put a greedy turbo kit with the intercooler
could u please give me more information on the big 16g turbo and a website where I can get one
thank u for your time
Old Mar 15, 2006 | 05:24 PM
ORIGINAL: B.e.R.a.T
Greddy turbos are not big in the Eclipse, the 16G is a mitsubishi turbo. RRE has them so does bushur racing and a bunch of others it is a cheap and fits with stock exhaust manifold too. EVOs come stock with one and they can make around or over in some cases 400AWHP.
Old Mar 15, 2006 | 11:10 PM
93eclipsegsx's Avatar
i got my 16g from extremepsi.com , they are pretty knowledgeable about heir stuff.
Old Mar 16, 2006 | 03:23 AM
B.e.R.a.T's Avatar
Thank u very much
I looked at extreme psi.com and found the turbo kit which is called Mitsubishi TD05H-EVOIII 16G is that the one u where talking about? it says it is cabaple of producing 380 HP and it requires the 2g eclipse turbo installation kit which is $150. if I buy this what else do I need to change in order to have all the power
Basically could u guys plesase give me a list of the things to do in order to get 350-380 Hp on my car. including turbo, intercooler, fuel pumb and injectors,BOV, exhaust and anything necessry to have a smooth running fast 2G eclipse on the streets of Columbus.
I appreciate for all your replies and time
Old Mar 16, 2006 | 08:36 AM
ok.. THe Turbo, install kit, Tubular manifol, full 3 in exhaust turbo back, FMIC, IC pipes upper and lower, MBC,FUel injectors,fuel pump,Fuel prssure regulator, SAFCII or something to tune with, Bosst gauge,EGT guage,Wideband maybe, Cams 272/264 or something, cam gears, clutch, BOV Greddy type S is good I guess, prob wont do it on pump gas c16 will most likely be needed on a dyno tune.
Of course with that much power on FWD I would strongly suggest bigger brakes, Springs,shocks,struts,camber kit, sway bars,strut tower brace, maybe some motor mounts and some nice Drag radials.
