fuel pressure settings
Old Sep 16, 2006 | 05:17 PM
gst4me's Avatar
Default fuel pressure settings
Hey guys as you know i just put in my new fuel pump (walbro 255) and new injectors (pte 550cc) and my new bov from mitsubishi.... I also put in a universal megan racing fpr. I know that the stock fuel pressure on my 98 gst is about 41 psi... what should I set the new psi at? Why is my fuel pump extremely loud? And when I hit the gas hard it pretty jumps off the ground. Whenever runnning it for a little while it pretty much messes up the idle and stalls. any help will be appreciated. By the way I will have my safc in about 2 weeks.
Old Sep 17, 2006 | 12:42 PM
Default RE: fuel pressure settings
well alot of the problems your having is the injectors. You really need to tune thos otherwise youll get what your getting. And for the fule pressure just set it to the stock idle pressure. So if your a 1g then set the FPR to around 27 psi and if its a 2g then set the idle pressure to around 35 psi
Pribs
Oct 30, 2007 08:54 PM
tdford
Sep 23, 2007 10:30 PM
turbokid
Jan 2, 2007 10:51 PM
maximus6770
Nov 15, 2006 09:13 PM
92_laser
1st Generation
27
Jan 31, 2006 04:39 PM
